I am having some troubles with a script I’ve created based off of the randomize panels script. I would like to have the script create a vertical brick pattern in the curtain wall with each panel 8’ tall and 1’ wide. I have done this by creating a curtain wall with the panels dimensions at 4’ tall x 1’ wide with the intention of deleting every second vertical segment in the list to create the brick pattern. I can get some of the grids to work but some of the time but usually only one row, as the “CurtainGrid.RemoveSegments” node does not delete the curtain grid segments I have fed into it from a list. I think there is something to do with the relationship between dynamo curves and revit curves, but I am stuck here. Would anyone be able to help me find a solution to this or help point me in a better direction please?
The first image shows the list selecting every second segment as intended, the second shows the script. The python node floating in there was just me trying to dissect the CurtainGrid.RemoveSegments node.
The script you started from has issues as it uses very out of date nodes and appears to not have been maintained. I actually converted my nodes to C# versions for stability. You need to update to the latest version of Rhythm for this to work. (If you are in Revit 2016, the latest version of Rhythm is unfortunately not working in that version though)
First we can verify the changes before we do them like so.
Ooooo, This is almost exactly what i was looking for, thanks folks!
Now just need to randomize it… @john_pierson
Looking at your older script about randomizing panel/grid removal and going to try and combine them…
The packages are literally listed above the nodes in the screenshot I supplied. However, this is a nearly 2 year old post so there may be some modifications needed of course.
