Is there a way to delete curtain grid segments when a mullion is delete or the other way round?
My dynamo program is selecting the horizontal mullions and deleting all except one random mullion.
Is there a way, in dynamo, to delete the grid segments that the mullion was “attached” to?
Maybe!!!
If you also can delete the grid line in segments.
Imagen that you have one horizontal mullions also and you want to delete the vertical mullions/grid under the horizontal mullions.
That is my mission:)
@Bardur_Thomassen It will work all the cases just need to tweak little bit. It would be better if you can drop your dummy files with images of your mission.
