Line Styles
Is there any way to create and delete Line Styles on Dynamo using Python.
All the solutions I found wants me to use the Bimorph Package and I don’t want to use it. As my dynamo script will be shared with other people who don’t use the Bimorph package
Awaiting for your response
you can do it via revit python shell, collect all the linestyles using FilteredElementCollector, get the specific line style name, then delete. For creation, you can also do via api, create the line pattern first, then set it into the line style together with all the properties, that way you won’t have to use any package on dynamo.
Any element in Revit can be deleted. You just need the ElementId of the object.
Document.Delete(ElementId)
Thank you @jmark and @aaronrumple for your guidance.
I was able to create and delete line style in python
Create:
clr.AddReference("RevitAPI")
# The inputs to this node will be stored as a list in the IN variables
# Place your code below this line
cat = doc.Settings.Categories
linecat =  cat.get_Item(BuiltInCategory.OST_Lines)
lineStyle = cat.NewSubcategory(lineCat, "NewLine");
lineStyle.LineColor = new Color(255,0,255);
lineStyle.SetLineWeight(2, GraphicsStyleType.Projection);
OUT = lineStyle
