Hi all,
I have 100+ families, is it possible to automatically delete only parameters with empty value and parameters with 0 value?
Probably this is the way: How to delete multiple family parameter from inside the project - #5 by MJB-online but I don’t know as to filter parameters.
Note: I have both 100+ individual families and all 100+ families loaded in the rvt file and no shared parameters.
Thank you.
deleting families = possible
deleting parameters = not possible (if it’s built-in parameter)
deleting parameter values = possible (but it means make it empty)
which one you want? a bit confusing.
delete parameters, but you said that is not possible.
why do want to delete?
Because I want a report (i.e. spreadsheet) where are present only “non empty” value parameters.
For example if you have 3 params, the first with value A, the second with value B and the third with empty value, in report i want only the first and the second parameters
