You can collect all families by using Python. Then you can filter by bool mask the duplicate ones. Good Luck!
<img src="//cdck-file-uploads-us1.s3.dualstack.us-west-2.amazonaws.com/flex022/uploads/dynamobim/original/2X/6/67ac7e5290d34d28ef220c1f8b6f476f0ca7f345.png" width=“690” height=“376”
You’re totally right. If you’re not careful and delete a family type through dynamo, all of its instances will disappear from your document. In this case, we’re dealing with a template file, so hopefully they’re yet to place any family instances
Hi All.
Thanks for all this help.
I have Dynamo 1.0 installed, Clockwork has not been updated for 1.0
I was able to replace the All Elements of Type node with the Python Script from Kulkul.
I got all the way to the last node Delete Elements, this node does not seem to be part of Dynamo, I’m guessing it is a clockwork node.
I ran out of time to install an older version of Dynmo to restart the graph.
Thanks for the help - I can see this will do exactly what I want.
Actually Tomasz_Puchala is correct.
I found out why I have a double up.
We have a drafting view that lays out all our detail families with their tags.
I imported the drafting view, this caused the double up.
