Hi Community,
Is it possible to define a function in a code block that gets a variable and return this as a project parameter?
In this fisrt case I tried to define the result of this operation as a function called “lot”. But when I create a code block to read this function it reads as “function: lot” and not as the value of this function. What to do? The same thing happens when I use a slider, as we can see in the image with the function called “oie”.
I also tried using the Prorubim package nodes, as we can see in the second image. In this second case i could only determine the value of the “ola” function that is associated with a integer slider. I could not determine the “hi” function associated with a var….
I want to create a function associated with a calculated var… in an operation that can be used as a project parameter, just as I used the “ola” function.
Can someone help me?
