Hi Guys, Sorry i’m newbie just still trying to draw cable on cable tray but always problem with cabletray connector
Is there any other method to draw cable without using node elbow by mepcurve ( the problem is on margins)
thanks for help
@sovitek @chuongmep any suggestions please ?
Les coudes que tu essaies de placer on l’air d’être trop grand entre 2 des chemins de câbles ce qui fait que 2 coudes viennent se toucher.
The elbows you are trying to place seem to be too big between 2 of the cable trays which makes 2 elbows touch each other
Yes OpenMEP is the way to go more stable…so @El_padrino try play around with this awesome package and it will work…
Awesome script, good job
Thx to your great package…so i will say thank you ![]()
Wow seems Awsome script thank you so much @sovitek but i still have error on fitting not working yet !
Hi…try L2 in your list count
Difficult to say then you have to show your whole graph with all nodes expanded so we can see whats goin on…but try as here…
CONDUIT.dyn (60.2 KB)
i tried your script same result !
Modélisation cable4_20230526.dyn (62.0 KB)
Hmmm could you share the rvt you test on…
may i have your mail adress ? cant send it here
Just upload it here, just a small piece
and if it too big you can use filetransfer,webtransfer etc. and then share the link here…or if its secret just send the link in a PM to me here ![]()
it’s not secret haha just example of cable tray
Cheers ![]()
allright here we have a situation with that big cross, then this method here will not work an that
…but will work on elbow and tee…another thing is you are in meters…and we work in mm here…but try this one here…i have test in 2022…
EDIT now it work in your case…try something here…
2022 CONDUIT.dyn (59.4 KB)
Amazing !!! thank you so much @sovitek you’re the best ![]()
