Data-Shapes - View result/output
I have a script setup to show the length of model lines for the length of path of travel. I can’t seem to figure out how to get Data-shapes to show me the output or result.
I know with player you just set the node to output.
You’ll have to create another MultiInputForm for that
I assumed that, I just didn’t see any nodes labeled as ‘Output’ so I was confused.
Do I need to run the watch node at the end into the input slot of a new multi ui node?
Yeh, could just plug your data into one of those forms with a null input.
Or you can use some python
clr.AddReference("System.Windows.Forms")
from System.Windows.Forms import Form,Label
def popup(text):
	form = Form()
	form.Width = 300
	form.Height = 300
	label = Label()
	label.Text = text
	label.Width = 300
	label.Height = 150
	label.Parent = form
	form.ShowDialog()
Text="\n".join(IN[0])
popup(Text)
It all depends on how you want to show the result.
A single line could use a TextBox, a list of item could use the ListView with Display mode only set to true
