**Data-Shapes Package Issue in Revit 2025**
Hi everyone,
I’m having an issue with the **Data-Shapes package** in Revit 2025. The nodes are available, but I’m not getting the expected output / the UI input is not working correctly.
**Versions:**
* Revit 2025
* Dynamo: 3.x
* Data-Shapes: **2025.3.119**
* Python: **2.7 v3.2.0**
I have tried reinstalling/updating the package, but the issue still occurs.
Has anyone faced the same issue or knows the compatible Data-Shapes/Python version for Revit 2025?
Thanks!
Out of curiosity, what is the form you are building? Or wanting to build?
Hi maybe im wrong but last time i tried datashapes in 25 it should run on cpython 3, when you open the nodes is that set to that
The latest Data shapes version is 2026.4.2 according to the package manager, and it indicates it supports revit 2025 and above. So this may include any fixes
Reason I ask above.
Interlude package makes UI forms for you, and as you know this is kind of hard to do. So, it works really well with Autodesk Assistant (Revit 2027.3+ and Dynamo 4.2.x+)
The full chat:
The UI built:
And the resulting Dynamo graph:
TitleBlockSwapper.dyn (63.9 KB)
I’m also starting to see an incompatibility with the latest Revit hotfix and the current Data-Shapes package. Per Autodesk’s Revit 2026.5 Update page, ‘Revit 2026.5 introduces updates based on .NET 10, which may cause compatibility issues with other products and addons.’
Included in the latest update is Dynamo Core for Revit 2026 - version 26.5.0.55
We aren’t having this issue with Revit 2026.4 and older.
I’m hopeful that there can be a quick fix with the Data-Shapes package, as most of our Dynamo tools use it.
Thanks very kindly in advance!
Hi, now I just start node of data shapes and as a start, I created auto duct/pipe insulation selected by levels, systemtype, insulation type and thickness..
