Hello all,
I’m having an issue with the “DataTable input” node in Data-Shapes. When I’m in Dynamo testing out my graph, it works fine with exporting and saving the table, and then opening it up in Excel. (Edit: It is now not working there either, even though it was working when I first made the graph) However, when I try and use it with DynamoPlayer, I get the error shown below.
Any ideas why this would be or how I can fix it? Also, does anyone know of a way to just remove the export option all together just in case that is my only option? Thanks!
Also, here is the graph just in case you may need to see it:
