Hi, I’m currently using Revit 2026 with Dynamo 3.6.1 and noticed that UI nodes like ListView Data from the Data-Shapes package are returning null.
Is there any roadmap or plan to release an updated version of Data-Shapes (or similar UI tools) compatible with Dynamo 3.x?
Also, is there any official progress from Autodesk on enabling CPython to access the Revit API (via CPython.NET interop)?
Thanks in advance!
The latest datashapes should work. Which version are you on? Have you missed a dependency?
My understanding is that this is more on the Python side of the tech than the Autodesk side - it’s like asking Toyota when Exxon will be making diesel fuel that works in a gasoline engine. Since Python isn’t likely to resolve it the team has moved to a new engine in Dynamo 4.0 (likely coming to a Revit version near you in the coming months).
