I am using Revit 2019 and DataShapes version (2021.2.93)… for some reason when I click the elements in the list-view of DataShapes form, they do not highlight in the Revit view…! The items to be highlighted are Revit 2D detail lines, so I wonder if it only works with Revit 3D families…!!
… needles to say, thank you @Mostafa_El_Ayoubi for the efforts in developing this package.
have you tried expanding your view window to see the element id’s at the end of the text listed? i believe if you click on the element id it should highlight anything selected
Thanks @NickDodge for your reply. I modified the dynamo (see capture) to get the ID of the elements.
The highlight element in view option seems to work naturally with 3D Revit elements … but not with 2D detail lines…!?
