Data Management... Civil 3D chokes on number ofelements
Hi all,
is there a way to Freeze the information inside a node without needing to reread it again, the node i want to freeze is the Solids elements.
In civil 3d i have around 10 000 Solid elements that im adding data trough Dynamo (Metadata), when i run the script to “read all elements” in the model i can notice this is where is choking with the amount of information i process, everytime i run the script.
Data.Remember from generative design should work.
