New to Dynamo. I have looked at many forums on this topic, but have not seen a solution that works or posts after '21. Could someone be so kind to steer me in the right direction or a solution for this. Many Thankyous
Hi.Post a sample of your data, tell us excel version you use.
Try making your data a 2d matrix (list of lists). As well as that try the export XML excel node instead as the one youre using often has issues with windows online repair states.
That worked perfect. Thank you Crump!
