I have still problem with join geometry or cut geometry…
Sometimes work sometimes not…
If work join/cut only one item…the other not…must manualy in Revit…
I used spring or clock node…
Is there some bug or doing some wrong.?
Hai all,
I am new to this dynamo, I had done a project on revit.
Now I want some details on how to join floors and structural framing in a revit file by running dynamo, because it is consuming time to join floors and structural columns individually by join command in revit. I heard and seen some videos on dynamo that we could run join geometry automatically by dynamo nodes.
Please share some video tutorial regarding floors and beams join geometry in revit by dynamo. It could be very useful for me.
Regards,
Welcome to the forum. I think it is better to start a new topic.
You get probably faster an answer
In case if you haven’t read the forum guidelines. I suggest reading the community guidelines.
https://forum.dynamobim.com/t/how-to-get-help-on-the-dynamo-forums/4677
