Cutgeometry dynamo 2023
It seems that the 'Element.CutGeometry Block from the good old dynamo is not available in the 2023 version?
Is there a new tool available or a workaround?
any suggestions?
Try clockwork cut geometry
@freark.van.der.sluis ,
you can build your own node …
clr.AddReference('RevitAPI')
items1 = UnwrapElement(IN[0])
items2 = UnwrapElement(IN[1])
def CutGeometry(doc, item1, item2):
	try:
		SolidSolidCutUtils.AddCutBetweenSolids(doc,item1,item2)
		return True
	except:
		try:
			InstanceVoidCutUtils.AddInstanceVoidCut(doc,item1,item2)
			return True
		except: return False
if isinstance(IN[0], list):
	if isinstance(IN[1], list): OUT = [CutGeometry(doc, x, y) for x, y in zip(items1, items2)]
	else: OUT = [CutGeometry(doc, x, items2) for x in items1]
	if isinstance(IN[1], list): OUT = [CutGeometry(doc, items1, x) for x in items2]
	else: OUT = CutGeometry(doc, items1, items2)
KR
Andreas
Yes @Draxl_Andreas thats how clockwork cut geometry is build…
