Customize UI Node in Dynamo
Hello everyone :wave:
I have implemented a custom node as per Mr. Chuong’s instructions. This custom node works as expected.
Now, I want to implement a custom node that has a dropdown like Dynamo’s default Categories Node. Can someone give me a specific guide to do this? Will the custom node become an input (like when we set the default Categories node to Input on Dynamo Player, allowing the user to select from the dropdown list)?
This is a good primer: NodeModel Case Study - Custom UI | Dynamo
But for a sample code you likely want to look into something like the dropdown nodes Dynamo for Revit: DynamoRevit/src/Libraries/RevitNodesUI/RevitDropDown.cs at master · DynamoDS/DynamoRevit · GitHub
Thank you so much @jacob.small
