I’m creating a custom node to wrap a string at a specified index, as you can see below the python scripts works properly until I create the custom node and use an integer lower than 10.
Obviously the custom node and the python script contain exactly the same code.
For me it works as well. Try to add the traceback library to check what is the Exception thrown. The if statement for length <= 0 is just to avoid 0 or negative values to be used.
import sys
sys.path.append(r'C:\Program Files (x86)\IronPython 2.7\Lib')
import textwrap
import traceback
text = IN[0]
length = IN[1]
def wraptext(tx, l):
b = textwrap.dedent(tx).strip()
for width in [l]:
c = textwrap.fill(b, width = width)
return c
try:
if(length <= 0):
length = 1
OUT = wraptext(text, length)
except:
OUT =traceback.format_exc()
