Translated by moderator. See below the line for original post.
Hi everyone, I’m trying to recreate a curved beam system in dynamo based on two mass surfaces that I imported from revit, but I don’t understand why some beams are placed above and some below the two masses, they are at the first weapons so forgive the inexperience, if someone can help me thanks
Original post below.
Salve a tutti, sto provando a ricreare un sistema di travi curve in dynamo basandomi su due superfici da massa che ho importato da revit, ma non capisco come mai alcune travi vengano posizionate al di sopra e alcune di sotto alle due masse, sono alle prime armi quindi perdonate l’inesperienza, se qualcuno può aiutarmi grazie
This is the result
Original post:
Questo è il risultato
@ame9931 …Could you translate to english
Yes of corse,I’m trying to recreate a curved beam system in dynamo based on two mass surfaces that I imported from revit, but I don’t understand why some beams positioned above and some below the two masses, in the image you can see the script and result
Cool…i dont know nothing about beamsystem but i am sure there are a lot of hardcore struc guys in here there will help you…welcome
okay, thanks per the welcome I’ll wait and hope for some solution
Maybe reverse the curves?
Left to right, or right to left?
Which way Ihave to follow to do that?
thanks, for what i see the problem is that some beams in revit have a cross section set to -180.00° so i put this value to zero ad solve
