Curve.SplitByPoints effect not reflected on Revit
Hi everyone,
I am trying to split structural framing element using the node: “Curve.SplitByPoints”. It works OK in Dynamo but no effects reflected on Revit (the element not splitted). What I missed.
Thank You
Hello @amahrouswork and welcome to the forum :wink: could you show an image where you are so far…you could try split by point from genius loci it should split the element…guess you just split the framing location curve right now
Thank You @sovitek
I am using Curve.SplitByPoints
I tried genius loci and splited the element
yes genius loci can do it…if you do it with curve spli node as you show you will need rebuild with beam by curve and delete the originals
