curve.PointAtDistance
Where can PointAtDistance method in revitapidocs?
That one do you mean?
https://www.revitapidocs.com/2019/95efa592-d444-acb8-6460-e2757b96e053.htm
That node was renamed to Curve.PointAtSegmentLength
actually i am not looking for the nodes. i am looking for the methods in revitAPI
Ah, I see. That’s a bit tricky to do in Revit. Try the evaluate method and set the normalized input to false:
If false, param is interpreted as natural parameterization of the curve. If true, param is expected to be in [0,1] interval mapped to the bounds of the curve. Setting to true is valid only if the curve is bound.
