Curve.ExtrudeAsSolid
http://dynamobim.org/geom101/
I saw in this and many tutorials that the node Curve.ExtrudeAsSolid is used to extrude different curve at same height. Do you know how to create a definition that extrude a list of curves with a preset list of height(string or values)?
I tried to do that but seems like the node Curve.ExtrudeAsSolid don’t accept arrays…
Thank you for your help
show us the error message
Curve.ExtrudeAsSolid needs a closed curve and can’t handle polycurves
Hello. If you mean you want sides of a solid extruded to different heights (like each face extruded to a different height), try extruding as surfaces first then join them all into a single solid.
http://dictionary.dynamobim.com/#/Geometry/Solid/Create/ByJoinedSurfaces
If you mean like using two curves from different views, there have been several threads on how that has been done if you want to try searching for it.
@jacob.small’s post in Curves from two views shows one example.
Now I have this definition, and it extrudes every polycurve by 15000 mm… If I try to change the distance from a single parameter to a list of values, it appared me this error…
“Warning: One or more of the input types are not matching. Couldn’t find a version of ExtrudeAsSolid that takes arguments of type (__array,Autodesk.DesignScript.Geometry.Vector,__array)”
So how it’s workflow to handle different polycurves…? I don’t know this logic step, and I couldn’t find it in the forum
try this
other example:
quite What I wanted (I tried it already, but it wasn’t the results I wanted to achieve)
Imagine that, instead of regulare list, I have a list of values as in figure… how can I convert them to block?
it is the same…a codeblock list is like a normal list, only created with another method
look:
u need to show us the error u got!
In my example i get this warning because the values are to high for the geometry creation
