Hi All:
I am trying to set the mullion types (Border Type 1, Interior Type, Border Type 2) in the type properties of a curtain wall. I am able to successfully do it more/less, but there is one problem. When I use the SetParameterByName node, it doesn’t fully work since there are typically 2 of each of the above parameters, named exactly the same way, one for verticals and one for horizontals.
Does anyone know if it’s possible to set these individually another way. I’ve been sort of successful by pushing the same parameter name 2 times to the set parameter node, but it works sometimes and not others…Thoughts?
Thanks in advance!
