CS21553: Construction Dynam(o)ite—Explode Productivity with Dynamo
I followed an autodesk university tutorial , I’ve taken all steps , but I couldn’t create 3D views of clashes elements . I dont know why the final node was not working.
Error : “Warning: No function called SetParameterByName on a Function that takes string,__array could be found”
@Dieter_Vermeulen help me please mate!
Might want to upload some screenshots of where you are at.
I solved that problem thank you, but if you help me in this matter, HELP ME
Create Duct From CAD.dyn (7.6 KB)
First of all post your solution to your original problem, if you are not prepared to share your solution and help others you cannot expect help in return, secondly create a new topic for this new problem…
You are missing a node and have not chosen any element in your model…
