Cross-Section Volume Calculation Between Multiple TIN Surfaces (Layered Dam Embankment) – Civil 3D + Dynamo
I am working on a dam embankment model in Civil 3D and I need to automate volume calculations using Dynamo.
Current setup (see attached image):
  • Multiple independent TIN surfaces representing structural fill layers constructed every 0.35 m (blue lines in section).
  • One TIN surface representing the dam design geometry (black line).
  • Existing ground and foundation surfaces are also present.
  • Cross sections have already been generated using Sample Lines along an alignment.
In the attached section view:
  • The red cloud highlights the volume between two consecutive fill layers (layer-by-layer as-built volume).
  • The green cloud highlights the portion of that layer confined inside the dam design surface.
What I need to automate:
:one: Volume between consecutive fill layers
For each cross section:
  • Extract the section geometry of two consecutive TIN surfaces.
  • Compute the bounded area between them.
  • Integrate volumes between stations (average end area method).
:two: Volume of each layer confined inside the dam body
  • Compute only the area of the layer that lies inside the dam design surface.
  • Then compute volume between stations.
Important constraints:
  • Calculation must be based on section geometry, not global surface-to-surface volume.
  • All layers are independent TIN surfaces (not corridor shapes).
  • I need an automated workflow in Dynamo.
  • I am open to using Civil3DToolkit, Camber, or Python nodes if necessary.
Has anyone implemented something similar?
Specifically:
  • How can I extract section intersection geometry from multiple TIN surfaces?
  • What is the best way to compute bounded areas between surface profiles in Dynamo?
  • Is there a recommended approach for handling this per station?
Any guidance would be greatly appreciated.
Thank you.
I am currently using:
  • Civil 3D 2021
  • Dynamo for Civil 3D (included with Civil 3D 2021)
For better understanding of the geometry and surfaces, I am attaching a download link to the DWG file of the dam model:
DWG file download link:
Please feel free to review the file if needed.
