Hello, I want to crop surface with multiple boundaries
I made a code which crops for just one boundary how to do the same with multiple ones?
Crop.dyn (8.4 KB)
Crop.dyn (8.4 KB)
I’d say instead of pick point, make a patch surface from each crop polyline, then thicken into thin solid, then use the centroid node to get the center point and feed that into keep location and see if that works.
Thank you works like a charm ![]()
Hi Beka,
I am also looking for same kind of Dynamo script but as I don’t have much knowledge I am not able to make changes as per Kirk Suggestion , if its fine for you can you please send me your final .dyn file?
I would be very thank full for your help.
Msurface_Crop.dyn (19.2 KB)
Here it is
Thank you so much Beka_Tchighladze . You made my day today.
Thanks!
With Greatest pleasure ![]()
