Create cropped surface C3D - Dynamo/ Python
Hello there, I’m trying to develop a Dynamo and Python code to create a cropped surface within the same file as the source surface.
Due to my workflow it’s a waste of time do the same process over and over again (save file, select boundary, select existing/ create new file/ name/ etc). So, I’m developing a Python code based on the C3D 2025 API’s TinSurface.CreateByCropping(Database, String, ObjectId, ObjectIdCollection, Point2d) Method
So far I have written the following Pyhton code:
However, after executing it, Dynamo retrieves the following message:
"Warning: PyhtonEvaluator.Evaluate operation failed.IdentationError : (‘expected an indeted block’,(',35,17,‘src_surface = tr.GetObject (srcSurfaceId)\n’)).
Has anyone tried this before?. Can anyone please help me to troubleshoot this?
Try
Add to line 35
ArcSurfaceId.InternalObjectId
with statements need an indent (see python syntax)
Thanks for your answers. I have tried them and modified the code; however, it still doesn’t work. I have also verified the structure based on the guide Python and Civil 3D | Dynamo
Now, it retrieves the following message:
Warning: PyhtonEvaluator.Evaluate operation failed.IdentationError : (‘unindent does not match any outer indentation level; (‘’,45,31,’ t.Commit ()\n’))
Cropped_Surface.dyn (12.7 KB)
¿Any ideas?
CHECK Parameters Method WELL
