I’m trying to create vertical surface (following the Z vector) from the lines obtained from the perimeter of horizontal surfaces… However, when I try to thicken the curve to then create a surface, in some cases the curve isn’t thickened in Z vector… Any idea why and how to solve it… or perhaps another way to achieve this? The end goal is to use this vertical surfaces to do a geometry.split on the horizontal surfaces.
I’m trying to create surfaces by using the lines obtained from the node “Geometry.Intersect” and conveying afterwards this information into the node “Surface.ByPerimeterPoints”
I think the main issue is that the sublists of points for creating each surface have points in diferent planes. That might be the reason of this error:
“Warning: Surface.ByPerimeterPoints operation failed. Error creating Surface: Points are coincident Surface.ByPerimeterPoints operation failed. Error creating Surface: Points are coincident Surface.ByPerimeterPoints operation failed. Error creating Surface: Points are coincident Surface.ByPerimeterPoints operation failed. Unable to make wire from edges : WIRE_SELF_INTERSECTS2 – Wire has self-”
Do you have any suggestion how could I solve this? My goal with this workflow is to be able to calculate the area of the surface from the geometry intersected.
