Creation of curves "In" a drafting view
Dimitar, this is good, but I am afraid that it will fail a ton when dealing with anything other than Lines and Arcs. As far as I can tell ToDSType() doesn’t process NurbsCurves properly. It also, can’t do things like Ellipse or Circle. I started writing those methods last week. Here’s a work in progress for now. I am sad to say that Nurbs Curves in Revit are like dark magic and fail almost every time…I have had issues with closed nurbs curves as well as regular ones and opted to go with hermite spline (which is an interpolated spline through points) for most of the nurbs. You can see that they fail if curve degree is different than 3 as well. The list goes on…anyways here’s what i have so far:
#Copyright© 2015, Konrad Sobon
@arch_laboratory, http://archi-lab.net
clr.AddReference(‘ProtoGeometry’)
Import DocumentManager and TransactionManager
clr.AddReference(“RevitServices”)
Import RevitAPI
clr.AddReference(“RevitAPI”)
app = uiapp.Application
pyt_path = r’C:\Program Files (x86)\IronPython 2.7\Lib’
sys.path.append(pyt_path)
from System import Array
import math
dataEnteringNode = IN
dsObjects = IN[0]
_lineStyle = UnwrapElement(IN[1][0])
def toRvtPoint(point):
unitsFactor = 3.28084 #Revit works in Feet while Dynamo in Meters
x = point.X * unitsFactor
y = point.Y * unitsFactor
z = point.Z * unitsFactor
return XYZ(x,y,z)
def toRvtType(dsObject):
if type(dsObject) == NurbsCurve:
points = []
subCurves = dsObject.DivideEqually(16)
for i in subCurves:
points.append(i.StartPoint)
points.insert(len(points), subCurves[(len(subCurves)-1)].EndPoint)
controlPoints = ListXYZ
for i in points:
controlPoints.Add(toRvtPoint(i))
tangents = Autodesk.Revit.DB.HermiteSplineTangents()
endTangent = toRvtPoint(dsObject.TangentAtParameter(1))
startTangent = toRvtPoint(dsObject.TangentAtParameter(0))
tangents.EndTangent = endTangent.Normalize()
tangents.StartTangent = startTangent.Normalize()
return Autodesk.Revit.DB.HermiteSpline.Create(controlPoints, False, tangents)
elif type(dsObject) == Arc:
#convert DS Arc to Revit Arc
startPt = toRvtPoint(dsObject.StartPoint)
endPt = toRvtPoint(dsObject.EndPoint)
midPt = toRvtPoint(dsObject.PointAtParameter(0.5))
return Autodesk.Revit.DB.Arc.Create(startPt, endPt, midPt)
elif type(dsObject) == Line:
#convert DS Line to Revit Line
return Autodesk.Revit.DB.Line.CreateBound(startPt, endPt)
elif type(dsObject) == Circle:
#convert DS Circle to Revit Arc (for arcs with 2pi range will be automatically converted to circle)
center = toRvtPoint(dsObject.CenterPoint)
radius = dsObject.Radius * 3.28084 #converted to FT from M
startAngle = 0
endAngle = 2 * math.pi
xAxis = XYZ(1,0,0) #has to be normalized
yAxis = XYZ(0,1,0) #has to be normalized
return Autodesk.Revit.DB.Arc.Create(center, radius, startAngle, endAngle, xAxis, yAxis)
return dsObject.ToRevitType()
def makeRvtDetailLines(crv, _lineStyle):
detailLine = doc.Create.NewDetailCurve(doc.ActiveView, crv)
if detailLine != None:
detailLine.LineStyle = _lineStyle
return detailLine
def makeRvtDetailLines2(crv, _lineStyle):
bipName = BuiltInParameter.BUILDING_CURVE_GSTYLE
lineStyle = detailLine.get_Parameter(bipName)
lineStyle.Set(_lineStyle.Id)
return detailLine
def processListArg(_func, _list, _arg):
return map( lambda x: processListArg(_func, x, _arg) if type(x)==list else _func(x, _arg), _list )
def process_list(_func, _list):
return map( lambda x: process_list(_func, x) if type(x)==list else _func(x), _list )
#“Start” the transaction
rvtElements = process_list(toRvtType, dsObjects)
rvtElements = processListArg(makeRvtDetailLines, rvtElements, _lineStyle)
“End” the transaction
#Assign your output to the OUT variable
OUT = rvtElements
