Creating wall from double wall outline thickness from Autocad
I am creating wall from autocad outline. In autocad, wall line are not single lines.Please suggest any solutions to my node problems. The result are shown “Null”.
Hi @ChrisM1 is that walltype node from Wombat ? not sure it will work if in 24 or 25 try OOTB.
and when you have paired your curves up, then try loft them and try isolines for get center curve
Hi @sovitek , My autocad wall line are rectangular polylines. Any suggestions to make wall in revit by using dynamo node. I use WallByCurveandLevel , but it doesn’t work. Is there any idea to work?
can you share a small cad sample ?
RWG wall3.dwg (173.6 KB)
Thank you @sovitek . Here it is sample part of autocad.
thanks i can take a look later
I first have some time next week, but many times it faster create centerlines in cad, than do it revit/dynamo, depends how is draw and how messy it is, but everything is possible…..just how much time we put in in it, for sorting/splitting everything out…but will give it a try :wink: :wink:
