Creating Spot Elevation By Room in Plan Views
Hi everyone,
I am trying to find the way to automatically place spot elevation in plan views by the location of the room as shown in the image. I think that’s a very common task that anyone would face. We do have script to centering the room location and room tag so there should be way to place splot elevation just nearby it. I have tried with Clockwork node SpotElevation.ByPoint but it does not work. Does anyone have an idea about that?
Thank you everyone in advance
Can you show what you tried? What failed about this?
Hi, sorry the for the late reply.
Here is the script. The node requires a geometry vector actually. I don’t know how to convert the project coordinates to geometry coordinates in Dynamo. Also the node not requesting for feeding any Spot Elevation Type.
WhT is the warning on the node? Can you copy the warning text from the graph node manager?
Hi @tranduytankts you could try play around with genius loci and see if it could be better
Revit_NQjDqau4vU
and if you will try with clockwork then bend and end expect vector
Thank you sir. Finally I can make it done. Yes, I was not aware that the node requires a vector.
Thank you @jacob.small also for your support.
