Create a Spot Elevation at Floor plan by dynamo?
I would like to create a Spot Elevation on a Floor plan with a dynamo.
The building is multi-storey so I thought to locate Spot Elevation according to the same locate for each floor.
I don’t ask about ready solution, I ask about, is it even possible?
Does anyone have any suggestions, what nodes to use, packages?
Thanks for any advice
Thank you for being mindful about not asking for an out-right solution.
Yes, spot elevations are possible through Dynamo. Check out Clockwork, they happen to have a node for this:
Thanks :slight_smile:
