TrevorA
February 26, 2024, 2:08pm
1
Hi There,
I have a large numbers of Rooms that contain RGB data and would like to use Dynamo to automatically create the view filters and set the color based on the RGB data.
One example of the Room data in
RGB: 204,023.245
Would be very grateful for any help
Hello @TrevorA
Show us your graph and tell us where you are stuck so we can help you.
Show us how you call the room data, select the views you want to add the filters to, and see which viewfilter nodes you can find.
TrevorA
February 27, 2024, 10:38am
3
Hello gerhard.p,
I’m a bit stuck really, not sure if i have the right nodes at the moment.
Ideally need to create a filter for each RGB code to store it unless it can all be stored in one filter.
The display colour needs to automatically use the RGB code number if this is possible.
