Creating Roof By Footprint in Dynamo
Hi all!
Just learning dynamo and wanted to create a roof by footprint python node (instead of using a package) but can’t seem to get it working?
My aim is to give it 4 walls to input, it takes to location of those walls and builds a roof from the top.
Any ideas! :slight_smile:
import sys
dataEnteringNode = IN
# Place your code below this line
#from Autodesk.Revit.ApplicationServices import Application from Autodesk.Revit.DB import BuiltInParameter as Bip
from Autodesk.Revit.DB import Transaction
doc = __revit__.ActiveUIDocument.Document
t = Transaction(doc, "Foot Print")
walls = IN[0]
walls_lines = [wall.Location.Curve for wall in walls]
level = doc.GetElement(ElementId(694))
roofType = doc.GetElement(ElementId(45441))
footprint = doc.Application.Create.NewCurveArray()
for modelCurve in walls_lines:
    footprint.Append(modelCurve)
t.Start()
footPrintToModelCurvesMapping = clr.StrongBox[ModelCurveArray](ModelCurveArray())
footPrintRoof = doc.Create.NewFootPrintRoof(footprint, level, roofType, footPrintToModelCurvesMapping)
bbox = footPrintRoof.get_BoundingBox(doc.ActiveView)
bboxMax = bbox.Max
bboxMin = bbox.Min
corner1 = bboxMax
corner2 = XYZ(bboxMax.X, bboxMin.Y, bboxMax.Z)
corner3 = XYZ(bboxMin.X, bboxMax.Y, bboxMax.Z)
corner4 = XYZ(bboxMin.X, bboxMin.Y, bboxMax.Z)
bboxCenter = (bboxMax + bboxMin) / 2
bboxCenterPt = XYZ(bboxCenter.X, bboxCenter.Y, bboxMax.Z - 500 / 304.8)
sbeditor = footPrintRoof.SlabShapeEditor
vertex1 = sbeditor.DrawPoint(corner1)
vertex2 = sbeditor.DrawPoint(corner2)
vertex3 = sbeditor.DrawPoint(corner3)
vertex4 = sbeditor.DrawPoint(corner4)
vertex5 = sbeditor.DrawPoint(bboxCenterPt)
spLine1 = sbeditor.DrawSplitLine(vertex1, vertex5)
spLine2 = sbeditor.DrawSplitLine(vertex2, vertex5)  # Corrected variable name
spLine3 = sbeditor.DrawSplitLine(vertex3, vertex5)  # Corrected variable name
spLine4 = sbeditor.DrawSplitLine(vertex4, vertex5)  # Corrected variable name
t.Commit()
OUT = footPrintRoof
Welcome to the community @kyle.crossleyEFJ2F. :slight_smile:
I did a slight edit to your post to keep the formatting. You can do this yourself in the future by wrapping your code in triple ` marks.
As far as your current code goes, I am not sure what the issue is - can you post the warning to describe the resulting issue? You might want to look for ways to set the slope of the roof’s perimeter curves rather than shape editing the roof, as that will likely be more aligned with the typical UI generated roof.
HI Jacob!
Thanks! There so much information on here! no doubt ill be here trying to sort out my messy posts.
Thanks for getting back so quickly! as for the current error is this, however i don’t understand how it doesn’t know what Revit is? :')
Thanks Jacob :slight_smile:
Ah! I see the issue now. You haven’t configured the Python environment.
You’re making a call to the Revit class in line 12, but the Revit class hasn’t been added to the environment yet.
See the post here for an example of why we make the various imports: Create and Export 2D Lines Loop Profile Family - #4 by jacob.small
A good boilerplate template for Revit interaction can be found here: dynamoPython/RevitPythontemplateFile at 883c11fd62c3a2b35790a5e3fed87720bcd6e557 · Amoursol/dynamoPython · GitHub
Those are so useful!! Why are they so diffcult to find on here! :slight_smile: Thanks Jacob!
After reading through these posts and adding the base revit interaction at the start of my code. I its not struggling to reference the wall location? Im using the wall.Location.Curve at the moment but i dont think this is the correct use. either that or im missing something to import? :confused: Any help would be amazing! :slight_smile:
# Import geometry conversion extension methods
# Import RevitAPI
clr.AddReference("RevitAPI")
# Imports Ilists module into python
clr.AddReference("System")
from System.Collections.Generic import List as cList
# Standard areas for Current Document, Active UI and application
app = uiapp.Application
walls = IN[0]
t.Start()
bboxMax = bbox.Max
bboxMin = bbox.Min
corner1 = bbox.Max
bboxCenterPt = XYZ(bboxCenter.X, bboxCenter.Y, bboxMax.Z - 500/304.8)
t.Commit()
OUT = footPrintRoof
There are a lot of resources out there for learning the Revit API and Python interaction. The hard part is that most people jump in to solve a problem rather than learn how to build a solution and why it’s done the way it is. Dynamo suffers the same. As a result when searching for stuff to help you leant, so the content which helps you learn the reasoning often gets suppressed below the content which gives an answer to a particular problem. It also doesn’t help that the API for Revit and Civil 3D and other tools are often so complex that experts need answers to build their implementations… :frowning:
It’s a holiday here for me, but I’ll try and have a look at this later today when I have to sign on to check some emails and video chat with a friend.
I understand! I’m starting off new completely, but i prefer to look at working code to understand how it works. Every job i seem to see is so niche, but i will get there eventually :slight_smile:
Thanks Jacob! Enjoy your holiday, no rush at all! :slight_smile:
After reading through tit here seemed to be # stopping some of the imports. Still not working properly but moving further down the code removing errors as we go :slight_smile: Here is what im up to now.
The issue im having at the moment is the Wall.Location.Line with Wall.Location not having a .Line attribute. Managed to find this website and its proving useful! :slight_smile:
import clr #adds the Common Language Runtime to the iron python environment so we can call .net code
clr.AddReference("RevitNodes") #adds the Revit nodes namespace to the CLR
import Revit #imports the Revit namesapce into the iron python environment
#clr.ImportExtensions(Revit.Elements)
clr.ImportExtensions(Revit.GeometryConversion) #adds the Revit Geometry Conversion namespace ot the CLR
from Revit import GeometryConversion as gc #imports the geometry conversion extension to facilitate changing form Dynamo geometry to Revit geometry
clr.AddReference("RevitServices") #adds the RevitServices namespace to the CLR
from RevitServices.Persistence import DocumentManager #imports the document manager to the iron python environment
from RevitServices.Transactions import TransactionManager #imports the transaction manager to the iron python
clr.AddReference("RevitAPI") #adds the revit api to the CLR
from Autodesk.Revit.DB import IFamilyLoadOptions, SaveAsOptions, FilteredElementCollector, View, Wall, Curve #adds the relevant sections of the Revit API to the iron python environment
activeDoc = DocumentManager.Instance.CurrentDBDocument #sets the active document variable to the current revit document
uiapp = DocumentManager.Instance.CurrentUIApplication #sets the uiapp variable to the current UI application - doing this so we can set up the current app
app = uiapp.Application #sets the app variable tot he current application of the uiapp
wall = UnwrapElement(IN[0])
level = IN[1]
roofType = IN[2]
walls_lines = [Wall.Location.Line for wall in wall]
# Loop over the lines and convert them to curves
for modelcurve in walls_lines:
    footprint.modelcurve
footPrintToModelCurvesMapping = ModelCurveArray()
bboxMax = bbox.Max
bboxMin = bbox.Min
corner1 = bbox.Max
TransactionManager.Instance.TransactionTaskDone
OUT = footPrintRoof
Comment out all the lines after the one you are having the error with.
Then removing the ‘.Line’ from that line so it just reads Wall.Location.
Add a new line OUT = dir(walls_lines[0])
This will show you what you can do with the object type which you have.
Where did you get this base code by the way? Any chance Chat GPT was involved? Seems a bit complex relative to type of failure points we are seeing - I’d expect you to post ‘I am having a hard time’ at the first failure rather than write everything after that.
Hi Jacob! :slight_smile:
Base code is from here
Obviously its not in the same environment so its slightly different but apart from that, hes a really cool guy to follow! :slight_smile:
I’ll give those edits a go when i get home :slight_smile:
Thanks!
The forum is your friend, use it as such :slight_smile:
To find this post I simply searched for the method you are using: NewFootPrintRoof.
clr.AddReference('RevitAPI')
from clr import StrongBox
outline = IN[0]
level = UnwrapElement(IN[1])
roofType = UnwrapElement(IN[2])
footprint = CurveArray()
for o in outline:
    footprint.Append(o.ToRevitType(True) )
# A strongbox containing a modelcurvearray
roofCurves = StrongBox[ModelCurveArray](ModelCurveArray())
New_Roof = doc.Create.NewFootPrintRoof(footprint, level, roofType, roofCurves)
OUT = New_Roof
This code takes in the curves from Dynamo, extracted from the walls. If you wanted to take the geometry directly from the walls you would have to tweak it but I’m sure you can use the forum to help you get that :).
HI!
Thanks for you r help, however this is just creating a flat roof. I have seen many posts and even some basic nodes that do this. Roof.ByOutlineTypeAndLevel for Example. Im trying to make hipped roofs. Something that isn’t integrated into Dynamo. In revit you can either made a hipped roof by Extrusion or Hipped Roof Via Footprint. I’m trying to get the “Roof By Footprint” equivilent in a local Python Dynamo node without using a package.
Thanks for your Help though! These links are very descriptive and useful
