I have been receiving this error when running my python script to generate a roof form:
Any ideas why?
I am running Dynamo 1.3 on Revit 2016 on a Windows 10 machine. It’d be great to at least see if it runs on someone else’s machine.
Attached is my DYN file & Python script, as well as screenshots of both.
test_create_ceiling_py.dyn (4.1 KB)
pycode.txt (1.4 KB)
I’ve also attempted this route using dynamo nodes to receive the same error:
test_create_ceiling.dyn (14.3 KB)
I would prefer a solution in python, but something using nodes could suffice.
Hi, I just started using Python and I am still confused, but I’ve tried this script and didn’t give any error. If might be of help for you…
#Import Revit Nodes
# Import RevitAPI
clr.AddReference("RevitAPI")
lines = IN[0].ToRevitType()
level = UnwrapElement(IN[1])
type = UnwrapElement(IN[2])
output = []
#Create Curve Array
cArray = CurveArray()
mcArray = clr.StrongBox[ModelCurveArray](ModelCurveArray())
#Loop through lines
for line in lines:
cArray.Append(line)
#Start Transaction
#Create Roof
roof = doc.Create.NewFootPrintRoof(cArray, level, type, mcArray)
output.append(roof.ToDSType(False))
#End Transaction
OUT = output
