Creating a Roof in Dynamo for Revit
Is there a Roof Types node and something like a Roof.ByCurveAndLevel in Dynamo?
If not how do you go about creating a roof using one of the roof types from the revit document.
Hello and welcome to the forum! :slight_smile:
You will find lots of information to get started by typing your keywords in the search field, for instance:
For entry points to Dynamo, please see these pages:
http://dynamoprimer.com/en/01_Introduction/1_introduction.html
For further information on how to get help, please see here:
I typed ‘Roof’ into the search in Dynamo as well as the ‘Primer’ but there is nothing. Looks like you can not make a roof in Revit by using Dynamo.
Hi @Jay_Polding
Have a look at the “FootPrintRoofClass” in Revit API http://www.revitapidocs.com/2016/97eb52e6-5dfd-86b3-708d-aabcda389f4a.htm
Thanks for the reply (and for archi-lab tools, they are awesome). Still, looks like there are no OOTB Dynamo nodes which make a roof.
Okay, you’re making it too easy for me. I appreciate it for sure. I guess I’m just trying to make a philosophical point (to Autodesk) that Dynamo requires too much coding knowledge to do even ‘simple’ things.
Hi @Jay_Polding,
Have you tried the Roof.SlabShapeByPoints node from Clockwork package. I tried to create a roof through points.
And output is,
Also, please look at this link, http://dynamobim.org/forums/topic/floor-and-roof-slabshapebypoints/.
Vasu
Hi! I got the same issue. The script works perfect when using the floor node but i cant do the same when replacing the floor one with Roof.ByOutlineTypeAndLevel and of course changing the floor type with a roof type. I always get a null result in the roof.byoutline node and cant get why. Is there anything else different to be done when you need to create a roof instead of a floor?
Thanks a lot
hi @Kulkul how enter syntax in python script
