Creating Pipe Run From multiple polylines
I am trying to create pipe runs from multiple polylines, but I’m facing an issue where the pressure network is not aligned with the surface levels. I need a method that will allow me to assign the correct surface level to the pipe run.
Could you upload the files ? thanks
Sure
TEST.dyn (65.9 KB)
You can use pressurepipenetwork.setreferenceSurface from Civil3d Toolkit,then you must convert to camber to create the pressurePipeRun.byobject.
Yes it worked, thank you very much
