Create PressureRun from object (poly3D)
Hello community
I can’t create a pressure network from a 3D polyline
I tried nodes from the Camber package, but 3D polylines are not supported.
I tried to look at the side of the API, but without success because I do not master it completely.
Is there a possibility with a Python code? I tried but I don’t completely master this type of code either.
Is this possible through python?
See this
Hi @hosneyalaa , very interesting topic !
But I’m not sure how to use this data to make a script that works (python? syntax? API?)
Do you have an example of how to use the different information ?
you should to take time in to learn CIVIL 3D API
through
or
Setting up a .NET Project for Autodesk Civil 3D
