I am trying to create a curve/arc that increases in elevation to a certain level, then continuous flat on that elevation. Is it possible to draw a curve at a specified plane? As you can see from my picture, when I use arc @startpoint/endpoint the elevation is not consistent.
And a little side question. How do you get out the endpoint of a curve in the Code block?
Help is much appriciated.
