Creation of plane in the axis of a curve in view of intersection
Hello, sorry for the long title.
1/ Is there a node (or custom) that allows you to create a plane in the axis of the curve (like the Curve.PlaneAtParameter).
I have to do a rotation (it works)
It’s more to know if one knows a node.
I found a solution for intersection of curve (it works), I try to improve.
Mr. @Thomas_Mahon (Thank you very much for the explanatory videos on your site), in the use of your node Curve.IntersectAll (the curves must be concurrent visually?)
thank you
Cordially
christian.stan
Can you get to the curve of the section (in floorplan) itself and go from there?
Hello, thanks for the information, I will try to dig this track
But it seems to me that it may be preferable to know an elevation face and shift this one to the axis of the element to have the plane concerned.
have a nice day
edit:
Since I don’t have a great command of the English language (I think you were talking to me more about this section)
sorry for the misunderstanding
Cordially
christian.stan
Interesting use case. Hadn’t thought of using that type of method before. :slight_smile:
Thank you, well seen, the use of the coordinate system, all without custom node.
bright
cordially
christian.stan
