Hi Guys
Is there a way to get the X,Y points of ARC at specific Z point ?
Regards
Hi Guys
Regards
Finding X and Y shouldn’t be a problem as soon as you can select the point on your arc by its Z value…
can you show which node, can do that
Thank you
I would use the Z values of the start point of the curve, of the wanted point and of the end point and remap them between 0 and 1 with a Math.RemapRange node. The resulting value in the middle of the list can then be used with a Curve.PointAtParameter node…
Thank you, This is gd idea
I tried it and it works indeed
but I had to insert a Curve.Reverse node before Curve.PointAtParameter to make it work correctly…
@Mohammad_Nawar The intersection of the arc with a plane at the required height (Z) should do
this also gd idea I will try it, thank you man
