ZEROLUC
October 12, 2026, 12:30am
1
Hello everyone. I am working on a Dynamo project for Revit 2027 that involves automatically placing lighting fixtures from a DWG file.
I have linked the DWG into Revit and used Dynamo to extract the points where the lighting fixtures should be placed. As a temporary measure, I have applied a Z offset to move the points up to the ceiling level. However, the lighting fixtures are still being placed on the floor and oriented upward, as if they were illuminating the ceiling.
I have tried the Family Instances by Face and Family Instances by Host and Point nodes, but I have not been able to solve the problem.
I would appreciate any help or suggestions. Thank you!
It depends whether the family is ceiling, wall or face hosted.
It’s usually best practice (opinions will differ) to host the family onto the element that it is physically attached to i.e normally ceiling
It sounds like your family is face-hosted. Many families will have a ‘flip’ parameter
Best to post your Dynamo graph and the family
I agree with @Andrew_Hannell
To add; What i sometimes do is make a non-hosted light and just give it an offset from the floor.
PS
Question for all the Dynamo guru’s here.
Is it possible to check what is right above a point?
Because there isn’t allways a ceiling.
i.e;
Celing
Beam
Exposed ceiling (so the bottom of a Floor)
Not want to hijack OPs topic, but i think the question is also helpful for OP.
Raybounce nodes will return the projected point and the element it hits.
Use rayboune
you can find previous posts considering the same topic
Thank you for your suggestions. Unfortunately, the forum does not allow me to upload the .dyn file, so I will share a screenshot of the final part of my Dynamo graph instead.
As you can see, the points are correctly positioned at the ceiling level, but the lighting fixtures are still being placed on the floor and facing upward.
I would appreciate any suggestions on how to fix this.
here a solution with Python to get directly the Face Reference (ReferenceIntersector)
import sys
import System
clr.AddReference("RevitAPI")
def decoTransactions(func):
def wrapper(*args, **kwargs):
returnfun = func(*args, **kwargs)
return returnfun
return wrapper
@decoTransactions
def new_instance_byface(dyn_pt, ref1, ftype):
inst1 = None
try:
if not ftype.IsActive :
ftype.Activate()
dir1 = XYZ(1,0,0)
inst1 = doc.Create.NewFamilyInstance(ref1, dyn_pt.ToXyz(), dir1, ftype)
except Exception as ex:
print(traceback.format_exc())
return inst1
def getclosestfaceCeilling3(ds_pt):
global riCeiling
global riFloor
point = ds_pt.ToXyz() - XYZ(0, 0, 3.28084) # move down to allow process ray
vectorDirection = XYZ(0, 0, 1)
referenceWithContext_C = riCeiling.FindNearest(point, vectorDirection)
referenceWithContext_F = riFloor.FindNearest(point, vectorDirection)
result_clashs = []
for refContext in [referenceWithContext_C, referenceWithContext_F]:
if refContext is not None:
ref = refContext.GetReference()
prjPoint = ref.GlobalPoint
result_clashs.append([prjPoint.ToPoint(), ref, point.DistanceTo(prjPoint)])
result_clashs.sort(key = lambda x : x[2])
if len(result_clashs) > 0:
if referenceWithContext_C is not None:
referenceWithContext_C.Dispose()
if referenceWithContext_F is not None:
referenceWithContext_F.Dispose()
return result_clashs[0]
return [None, None, None]
@decoTransactions
def create3D_ViewContext():
global threeDview
global riCeiling
global riFloor
# create 3D view for Raybounce
viewFamilyType = FilteredElementCollector(doc).OfClass(ViewFamilyType)\
.FirstOrDefault(System.Func[DB.Element, System.Boolean](lambda x : x.ViewFamily == ViewFamily.ThreeDimensional))
fecMepSpaces = FilteredElementCollector(doc).OfCategory(BuiltInCategory.OST_MEPSpaces).ToElements()
threeDview = View3D.CreateIsometric(doc, viewFamilyType.Id)
filterCeil = ElementCategoryFilter(BuiltInCategory.OST_Ceilings)
riCeiling = ReferenceIntersector(filterCeil, FindReferenceTarget.All, threeDview)
riCeiling.FindReferencesInRevitLinks = True
filterFloor = ElementCategoryFilter(BuiltInCategory.OST_Floors)
riFloor = ReferenceIntersector(filterFloor, FindReferenceTarget.All, threeDview)
riFloor.FindReferencesInRevitLinks = True
@decoTransactions
def clear3D_ViewContext():
global threeDview
if threeDview is not None:
doc.Delete(threeDview.Id)
toList = lambda x : x if hasattr(x, "__iter__") and not isinstance(x, (str, System.String)) else [x]
padded = lambda l, max_len: l + [l[-1]] * (max_len - len(l)) if l else []
threeDview = None
riCeiling = None
riFloor = None
out = []
lst_dyn_pts = toList(IN[0])
lst_ftype = padded(toList(UnwrapElement(IN[1])), len(lst_dyn_pts) )
for dyn_pt, ftype in zip(lst_dyn_pts, lst_ftype):
newpt, closest_ref, distace = getclosestfaceCeilling3(dyn_pt)
if newpt is not None:
newinstance = new_instance_byface(newpt, closest_ref, ftype)
out.append(newinstance)
OUT = out
