Creating families with Dynamo
Dear All,
I have been trying to create a family object with Dynamo.
Due to some reasons there is no output. I can see a geometry preview in the Dynamo window and the open Family file, but a family object as such is not created. Attached is a screenshot of the node setup. Am I using the wrong components or is it just not possible in general.
Thanks for your help!
Hi @PAnand,
Please re-post your graph with preview on for all the nodes. Use camera button (top-right) built into Dynamo - it screenshots the entire canvas.
@PAnand Looking at your graph are you looking to create custom node or build graph in Dynamo workspace?
It is a custom node.
Did it work for you? I am still not getting an output.
Yes it is working as expected. If it is still troubling you i suggest you do your workflow in workspace. It helps you track easily.
And here is the custom node Tier 2 Raker Geometry (v1.0).dyf (6.8 KB)
Thanks a lot!
What kind of family is it?? can it be a specific family like window or door??
Good morning @Kulkul, this is very helpful, I have an additional question on top of this topic, is there a way to create more than 1 geometry from a list of solid geometries? Thanks!
create family 2.dyn (32.7 KB)
Try changing lacing to longest for Familytype.ByGeometry node.
use FamilyInstance.ByPoint node after FamilyType.ByGeometry node.
see below link
Thank everyone for your help, it works huraaahhhh! I am so greatful!
