Column Dimension.dyn (284.1 KB)
I am trying to create dimensions for columns but something is wrong ?
Hi @Ashraf.Bekhit if you are 2023 be sure you had ironpython 2.7 package installed EDIT dont looks like you are in 23
Not 23 I’m using 21, what should I do?
Just my mistake if you was in 23 you should install that package i mention, but if you are in 21 it isnt that problem
Thank you for your time and assistance but still I have the problem , Do you Know the reason?
no not really…could you create an image where we can see the nodes and all expanded…specially in the beginning where i can see you already have warnings
Hello @Ashraf.Bekhit …havent go trough all you graph, but in the beginning you have spell issue in you Structural Columns, that why it dont give any columns,try to go all nodes trough until you find the issues and then correct them…
PS think you need some sorting in your references, seems to work if you use ootb dimension by face and just feed in the surfaces…but if you want dimension by reference you will need a dimensiontype and not a string…
