Hello everybody,
I have created a column using extrusion surfaces and I cannot assign a thickness to it. Can somebody help me please?
When I create this using the nod Surface.Thicken I get the error message that the surface cannot be calculated
Many thnaks in advanced!
Maybe you could try a negative value, (have not tested it myself)
Thank you, good reference but unfortunately that did not work
Hello, have you tried to see with surface.offset to see if it only accepts the offset
Cordially
christian.stan
I have just tried it but again the error message appears that the surface cannot be displaced.
Try to make a 1/4 in this case then symmetry and assembly by union at the end
or create your object with a revolution
Cordially
christian.stan
that helped… thank you very much!
