I want to create a roof element in dynamo with two slopes, with a adjustable length and a array over the x plane. I can create a roof with the ‘Roof.ByOutlineTypeAndLevel’ node but that will make it a flat roof. Is there a way to add slopes at both sides?
Hi @r.Francis and welcome…wombat package have some nodes for roof there probably could work…
PS and keep in mind if you want with roof footprint the wombat node expect the same count of slope as lines…another way could be with roofpoints…
One more question, do you know why it won’t work with sloped glazing roof?
No not sure , but probably if you use ootb roofby outline, then i think Rhythm have a node for sloped glazing…but havent tried
EDIT something here should work for sloped glazing roof
