Creating a Parameter based on a shared parameter?
hello
is it possible via dynamo to create a parameter based on a shared parameter as can be done natively
the ht_linteau parameter is created from revit (all information is correct)
the ai_linteau parameter is created via dynamo, I cannot get a convincing result
Is there a solution or do we have to do it manually
thank you in advance
sincerely
christian.stan
I found a solution via Data-Shapes package
Thanks to the authors for the solution
Sincerely
christian.stan
