Having some trouble filtering instances of the same revit link within Revit’s own filter based parameters, so I thought I’d try dynamo.
Basically I have the same link of a unit type copied multiple times within my tower. I have renamed all the unit instances to refer to their unit number (i.e. 101 for level 1 room 1, 610 for level 6 room 10, and so on).
I can go an un-check the units that i don’t require in each view, but that is very time consuming and somewhat annoying. Since I have already named the individual units via the RVT Links identity data ‘name’ parameter, is there a way to filter these unit instances so I can only see the units that begin with the first number of its identity data name (for example, if I have a view open for level 2 I then only see all the rvt link instances that identity data names begin with 2?).
I don’t think this is possible to do with revit’s integrated filter options. I have tried a number of methods, but I can’t get the result I am after referring to the identity data name.
Any help or advice is appreciated.
