Hello Community!
I need to create walls in multi- storey building using rooms’ curves, heights (volume/area), levels and one type of the wall.
I am using Lunchbox Room Element Collector to create inputs to the node Wall.ByCurveAndHeight
this node is limited in such a way, that Curve inputs every instance of the wall, while “height”, “level” and “wall type” are category inputs, and can be only 1 value per node.
I worked out the solution ( see script attached called home2.dyn), but now Dynamo does not allow me to channel element to neither of Element.level or Room.level.
Please, suggest if there any simple step that I am missing
Thank you!
full node sequence:
