Create viewfilters> duplicate 3D views> and apply created filters + override to duplicated 3D views
This issue is a follow up on the script i developed with some help of the community members here:
Create view filter based on different categories and type parameter - Revit - Dynamo (dynamobim.com)
Now I am trying to take this graph further by applying the created viewfilters to duplicated 3D views with the given override. (one filter with the same code as the 3D view name) This is what i Made:
Everything goes well, only the filters are not applied to the 3D view (one filter per 3D view) with the given override. I tried to solve this issue, but mabye this is a incompatibility issue with the archilab node, or am i missing something entirely else?
Also here is the graph i made, and it is important to use the given excel (excel input) and revit file (revit input) as well to get all the elements of the given types.
create viewfilters and viewfilter aplied views based on assembly codes.dyn (68.1 KB)
create viewfilters and viewfilter aplied views based on assembly codes.rvt (4.2 MB)
nl-sfb-2019-classificatiecode-variantelementen-assembly-code_hoofdgroepen.xlsx (12.0 KB)
Hi @olivar.wasely …does it work for you with ootb nodes…
Hi @sovitek , Thank you very much, this works!
